can't find the fuel pressure regulator......
ok guy's where do i find the fuel pressure regulator on my 4.3 motor
I believe its located on the rear of the engine at the top. Just remove your intake and then look right behind it, you should see the supply and return lines going into it.
Location depends on year... Crucial information to provide if you want accurate information...
it's a 2001 trailblazer 4.3
The FPR is inside the intake plenum on the back of the fuel injection spider metering body accessible after removing the upper intake plenum.
ok thanks guys,
Terje
11-04-2017 08:19 AM
bigdaddykane93
33
12-09-2012 02:31 PM
randymac
02-16-2011 12:47 PM
91chevywt
05-20-2009 10:13 PM
jlinder
08-21-2005 11:08 AM
