Distributor & timing problem
I just replaced the intake manifold gaskets on my 1999 Blazer. The gasket set that I bought came with a one for the distributor. Someone had this apart at some point before I bought it, and they didn't put a gasket under the distributor. Now with the gasket in there, the distributor sits up slightly higher than before and the mark that I made on the rotor and distributor doesn't exactly line up.
Should I leave this gasket out and just put some silicone in there? If I leave the gasket in, will the computer adjust the timing to compensate for the change?
Thanks for your help!
___________________________________ EDIT ___________________________________
Ok. After looking at it again, my problem is the distributor isn't engaged with the oil pump shaft. Tomorrow, I will try the procedure that I found on here to align the oil pump with a screwdriver.
Doctorvette
11-05-2012 11:57 PM
jimnva
05-03-2012 05:52 PM
