engine code p1683
thanks i kinda figured it had something to do with the pcm, guess my next question would be if i took one out of a 2002 4 door blazer would it still need to be reprogrammed? i have a 2002 4 door
Well because I moved the computer to take out and check my coolant tank figured i should clean the contacts on the computer , then had it checked they say it is fine no issues.. been a week and no code ,So figure I will drive it . Running great so will continue to monitor it almost at the 400 thousand mark..
djboyzs
10-14-2013 07:14 PM
stlwaco
12-17-2010 12:38 PM
