Engine running too rich until warm up
I have 1993 S10 Blazer 4.3 tuned port. I have taken it to 2 shops that are fairly knowledgeable. Fuel injector assembly has been checked, sensors checked and replaced to attempt something. It runs smoother after coming up to temperature, but wont pass emission test. The last shop I had several hundred in troubleshooting labor and stopped when he said maybe wiring to ecm, ecm or ecm chip. This was about a year ago and now need to pass emission test. I purchased another ecm and swapped it and it was no better. What do I do change chip?
There might be an issue... These trks only like ac delco ignition parts! Anything other and u run into issues.....cap,rotor,plugs & wires... It might be a long shot, however I wouldn't use e3 plugs.........
syriusly
02-23-2013 07:04 AM
Chastity
13
01-10-2011 07:22 PM
uncledenny
01-08-2010 04:09 PM
