Engine swapping
Engine swapping
Hi im trying to put a 96 blazer motor the 4.3 into a 2000 chevy blazer.the 96 motor is a spitting image of 0f the 2000 but there are some differences in the. Such as the abs system from the 96. The 2000 does not have the same braking system. And there is no relay center in the 96 like there is one in the 2000. So i would like some help and info on the abs system im having problems with. And the wiring is different but im trying to put the 96 motor and wiring harnes in the 2000.
Plz any thoughts would b much apperciateed. Thanks
You could use a 96 motor in a 2000 as long as the knock sensor mounting is for the same 1-wire knock sensor. Switch everything down to the intake & exhaust manifolds from the 2000 onto the 1996 engine and use the 2000 wiring harness.
rickward
06-24-2015 07:23 PM
