fan clutch questions
I put in a new fan clutch and the mother roars until you rev over 2-2500rpm
We have cold weather here but even after letting it warm up for a good 10 minutes it still roars until I roll down the street and get the RPM up
Once I rev it up it goes quiet and its good for the rest of the drive
Doesn't seem to do it after short stops
is it possible the blade is bolted on backwards(PO)?, I put it back on the same way it came off
mine does the same thing. only the first time i start it for the day it stays all pissed off and loud until i open it up a little after i get on the main street. has been doing it for a little over a year now.
My 99 ZR2 and my 05 Colorado do it also but not all the time. Just occasionally. I thought maybe that was because the clutch was engaged when I turned it off last drive. However when it does do it like yours they quit after a certain rpm. Must be normal. My Truck has done it since new.
Normal on a cold start up. If it doesn't roar cold, it's broke There are two chambers in the clutch. Once the fluid in the clutch warms up, or you hit 2500 rpm, the fluid transfers to the second chamber, and the fan slows down. It will remain quiet, (clutch slipping) until the engine starts to overheat. Fluid will transfer back to the first chamber and the fan will roar to provide extra cooling. If it doesn't stop roaring, or never roars, the clutch is bad.
I can not believe that even B/N that much noise would have ever been acceptable
if it wasn't the wifes DD in winter I would remove it all together until spring
