firing order
Old 04-01-2007, 10:34 PM
bigt's Avatar
bigt is an unknown quantity at this point
Default firing order
I have a 1984 2.8 v6 4 x 4 that is carburated. On the distributor cap I know where number 1 piston fires from and that it turns clockwise does the wires follow suit with the next one going clockwise number 2, 3, 4, 5, and 6? Also does anybody know what size the water pump bolts are? I am missing the bottom two on the right side and what size the bolts are that hold the alternator bracket to the head? Thanks!
Old 04-02-2007, 12:15 AM
Hanr3's Avatar
Default RE: firing order
I believe the firing order is 1,6,5,4,3,2.
Not sure about the bolts. You may ahve to call the dealer and get the right ones.
Old 04-02-2007, 10:41 AM
bigt's Avatar
Is it then 1, 6, 5, 4, 3, 2 on the distributor cap in a clockwise order? Thanks
Old 04-02-2007, 10:48 AM
Per Autozone.com under Repair Info:
Code:
Firing order 1-2-3-4-5-6                     -------
                                      front  | 1 3 5 |
                                        of   |       |
 Distributor rotates clockwise       vehicle | 2 4 6 |
Old 04-02-2007, 10:37 PM
bigt's Avatar
Thanks!
Old 04-03-2007, 02:34 AM
Hanr3's Avatar
Thanks for the correction Kyle.
jerseyjim
Engine & Internal
01-17-2007 12:14 AM
Dj7763
01-10-2007 06:03 PM
USMaverick101
10-20-2006 06:46 PM
tesshin
09-11-2006 10:05 PM
Rahmir
08-16-2005 12:52 PM
Quick Reply: firing order
