Fuel pump 2 / 3 outlets
Hi,
It has been a while but the Blazer in Holland is getting there!
I have now a question about my fuel pump. In that region it quite smells so I am guessing my pump is leaking internally (no spills visible). I want to replace it with another pump that I have, but there is a difference. Currently my pump has 3 outlets, so including return line. The other pump only has 2. Can I just use that 2 line pump without making any adjustments or is this going to give any problems?
Btw, it is a 350 engine.
BR
Alain
BR
Alain
If you want to replace it, I would stick to the 3 line pump. The 3 lines are outlet, inlet and vent and all are important. Is there any loss of pressure or are you wanting to replace your fuel pump based solely on smell? If all else is fine, you may just want to leave it if there is not any obvious leakage.
BouncingRadical
14
11-27-2015 12:30 AM
trailblazer333
TrailBlazer GMT360/GMT370 (2002-2009) Tech
06-24-2007 09:41 AM
mytruck2
12-13-2006 04:50 PM
