fuel spider ???
Old 10-14-2009, 07:53 PM
PFCBarner's Avatar
PFCBarner is on a distinguished road
Question fuel spider ???
I own a 1995 Blazer 4.3 vortec before i left for training for the marine corps i was having problems with fuel delivery the motor was idleing rough starting hard sometimes wouldnt start at all after pulling plugs i found some cylinders had lots of fuel in them squirted me in the eye when cranked over i was told by friend fuel spiders would cause that but he also had alternator checked and and it was bad also it was cranking slow starter also bad so there bein replaced but what causes the excessve fuel in engine any help would be great ill be home in november and will need vehicle asap PLZ help
Puzzled marine
Old 10-14-2009, 08:03 PM
Common problem. The FPR (fuel pressure regulator) in these CPI engines are known for their failures. The FPR is available separately for much cheaper than the whole CPI spider, but if the engine has a lot of miles, it may be a good time to replace the whole thing. The poppet nozzles used in the spider like to gum up causing further drive-ability problems.
If, during the course of your repairs inside the plenum, you remove the CPI spider, you will want to replace the fuel feed & return lines. These lines are commonly referred to as the 'nut kit'.
Welcome to the forum and thank you for your service!
Old 10-14-2009, 08:21 PM
PFCBarner's Avatar
thanks for the help ill take a look when i get home
also will it be called the nut kit at a parts store on advance autos page they sell the FPR and BWD unit with lines and all .......no poppets sold seperately
Old 10-14-2009, 08:41 PM
Advance calls them the fuel line connectors. BWD part # 28430 & Dorman part # 55163.
The FPR is available as a Motormite part # 55162.
They call the spider an "injector" and it is AC Delco part # 217-1431 & BWD part # 57096Z. You should be able to find the AC Delco spider cheaper elsewhere (Amazon & SummitRacing both have the AC Delco spider for a little over $300).
Old 10-14-2009, 08:51 PM
PFCBarner's Avatar
man im glad someone can give straight answers thanks a million
Old 10-22-2009, 11:09 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
so did you change your spider injector yet? if so how did it work out?
Old 10-23-2009, 09:18 PM
PFCBarner's Avatar
no i didnt change it im in missouri training i go home on november 5th and thats when i hope to make it run again ill need it to get to north carolina i will update with results
aerovette99
46
09-28-2015 10:04 AM
hunter05
34
01-18-2015 12:36 AM
hunter05
03-29-2014 11:32 AM
Big Eazy
04-27-2013 12:48 PM
nate2003456
02-08-2007 12:03 AM
Quick Reply: fuel spider ???
