problem with carb.
problem with carb.
i bought the edelbrock carb 600cfm manual choke 1405 is the part number. k, the problem is i had a holley 4 barrel carb that leaked. so i bought the edelbrock carb and i cant find a carb kit and my throttle cable, the cruise control cable and transmission line wont go on the carb. what do you guys recommend? is there a carb kit for my carburateur
RE: problem with carb.
anyone please help i cant find it and i only have 1 month before the snow hits
So you just need the connections to your cruise, throttle, and kick down cable? Is the throttle linkage on the side of the carb even spaced like your original carb? If not, then most carbs require the removal and replacement of the primary throttle shaft to swap the bracket on the end.
oh ok yah the major problem is theres no place to connect it and no parts that i can find such as a plate ect to hook everything up
Manley_pm
12-19-2005 11:18 PM
