HELP--whine from front of engine
2006 Trailblazer, XLt, V6, 4.2l 4x4.
There is a whine coming from the front of the engine. Like what the power steering pump makes when turned all of the way to right or left. But the whine happens all the time and gets louder when driving. People can hear us coming or outside the house when we pull up. Thought it was possibly a bearing or something going out in the alternator, since it is on that side of the engine. Replaced and still happening. If you want to hear the sound, listen to attached file. We are having an issue with the 4x4 and I am not sure if it is related to that, which is it wont go into 4 wheel drive. This sound happens when it is in 2 wd and all the time. No difference if AC is on or off.
Thanks for your thoughts! Changed power steering pump and water pump too, but nothing changed. Figured it out to be the belt idler pulley. The bearing in it was shot. Being its right below the alternator, that is why it sounded like it was coming from there. Nice a quite now.
Billyclubz
02-07-2012 06:04 AM
neksys
02-05-2012 04:32 AM
SoCalBlazer99
10-17-2011 02:14 PM
jimmydread
02-24-2009 10:31 AM
