2002 engine problems
Old 03-09-2009, 06:40 PM
bjburrisnc's Avatar
bjburrisnc is on a distinguished road
Exclamation 2002 engine problems
I have a 4x4 2002 chevy blazer with a 4.3. it runs very rough sounds like it is missing out. we put new plugs and wires on it along with the MAP and MAF. I replaced the TPS. nothing has helped. I can unplug the TPS and it will run fine it just wont idle after I give it gas. any ideas?
Old 03-09-2009, 08:21 PM
Have you removed the throttle body and cleaned it?
Before you replaced the TPS sensor (or any of the sensors for that matter), did you actually test anything to make sure that was your problem?
Old 03-10-2009, 12:35 AM
bjburrisnc's Avatar
I have cleaned it. TPS was bad the spring in it was broke. it was giving a random cylinder misfire code. after changing the TPS it was giving a code that said MAF Circuit low volt. low. I think ill look it up and give you the codes. I have cleaned it. I did have to replace the converter on it.
sorry typed that wrong i have not cleaned it.
Old 03-10-2009, 07:58 AM
Let us know the specific codes still being stored and we will go from there. You have replaced some expensive parts already. No sense in continuing that trend without confirming that parts are actually faulty.
Old 03-10-2009, 10:41 AM
bjburrisnc's Avatar
Codes are P0102, and P1345. the last one is new 1st time its had it.
Old 03-10-2009, 10:57 AM
P0102 - Mass Air Flow Sensor Circuit Low Frequency
P1345 - Crankshaft Position [CKP] Camshaft Position [CMP] Correlation
Have a read through the diagnostic charts and let us know if you have any questions. You can also search on those codes and should turn up other threads where people have experienced the same codes.
skygodtj
05-23-2012 09:08 PM
skiextreme2
04-14-2011 11:58 AM
Lodi Dodi
11-12-2010 06:26 PM
Compucents
04-17-2010 01:09 AM
upblazer95
04-04-2009 08:27 PM
Quick Reply: 2002 engine problems
