hesitation/hiccup/bucking @ 2k rpm.. ideas? - Page 2 - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 01-23-2009, 09:20 PM
ptg327 is an unknown quantity at this point
Default RE: hesitation/hiccup/bucking @ 2k rpm.. ideas?
anybody got anything to say? I unpluged the TPS and it didnt do anything so im guessin that would be the problem.
Old 01-23-2009, 09:33 PM
TPS is easy enough to test...
Old 01-27-2009, 06:06 PM
WellI replaced the TPS and it is still acting like a turd. anybody got anything because im stumped
Old 01-28-2009, 07:37 AM
Did you test anything before just throwing parts at it?
Old 01-28-2009, 10:22 AM
Nope, I just rushed into it.I know I should have but i just prayed that it was a simple sensor swap. May I ask what you suggest? Also my problem is slightly different. When i am stopped and put my foot on the gas it won't rev or anything it just bucks, hicups, misses and such. But onceI keep my foot down long enough maybe for about fivetofifteen seconds it runs and goes like perfect. When i stop at a stop sign or at a light, it more than half the time will stall out.
Old 01-28-2009, 10:30 AM
I suggest you test it as I suggested above... Plenty of information is available here and through a quick Google search.
If you do not have a good ground, the proper 5V reference voltage to the TPS sensor, or the PCM is not getting the appropriate information from the sensor, then replacing the sensor will do nothing. At that point, it is a wiring issue not a sensor issue. Wiring can be fun and you need to be diligent to work through it.
And that is not saying that it is the TPS sensor to begin with. It is possible that a knock sensor is picking up something that it does not like at that specific RPM, causing the PCM to retard timing, further causing the hesitation you note. It could be something completely different as well, but you always need a starting point for any diagnosis or you will just end up replacing parts haphazardly which may fix the problem sooner or later, but will not be kind to your wallet.
Old 01-30-2009, 07:17 PM
corvette535 is an unknown quantity at this point
well i'm gonna check it out tomorrow. i'll start with the ground wire and test out the tps... the other thing i heard was the igition coil could be a problem... any merit to this? how should i test it?
I only get the problem at around 70mph....i tried to get it to hiccup at other speeds at 2k under light throttle and it seems fine. since most of my driving in this thing is under 65 its not a problem, but i'd like to solve it so i can travel a little faster if need be.
thanks!
Old 02-06-2009, 07:20 PM
Ok so I checked the TPS wires and came up with a solid 5v. Then went on to fuel pressure. With the ignition key in theon position(not started) it jumped to 70 and settled at about 63,64. Then i went to the distributor which was loose for some reason. I fixed that but in the process I put the wires back on wrong because the previous owner had the distributor in the wrong wayso when i put the wires back onwhere they should have beenand started it.KA BOOM goes my muffler. Anyway thats all squared away now that the distributor is where it should be. ButI am still having the same issues listed in above posts???
Old 02-06-2009, 08:48 PM
Having 5V at the TPS sensor is only half of the equation. You also need to make sure that the output goes between 0.5V at closed throttle and 4.5V at wide open throttle.
Old 02-06-2009, 08:54 PM
I did a real good run down of the wires and found no problems. Should i still check it
Closed Thread
Thread Thread Starter Forum Replies Last Post
Need Help With my trucks hiccup/hesitation! PaulO2288 Engine & Transmission 5 10-24-2013 09:13 PM
1996 s10 blazer hesitation / bucking / surging linegtdt52 2nd Gen S-series (1995-2005) Tech 13 02-27-2012 09:23 PM
slight hesitation or hiccup 97cherryblazer 2nd Gen S-series (1995-2005) Tech 4 06-15-2011 07:37 PM
constant speed + low rpm = bucking? jeffs91S10blazer 1st Gen S-series (1983-1994) Tech 7 03-03-2010 10:53 PM
hesitation/hiccup/bucking rusignuolo Engine & Transmission 1 02-19-2009 07:49 AM
Tags
1992, 2000, 2k, 43, 95, blazer, bucking, chevey, chevy, grid, hesitating, hesitation, hiccup, hiccupping, s10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
