will a 700r4 interchange with a 4l60e
Old 10-22-2009, 11:36 AM
Roosawl's Avatar
Roosawl is on a distinguished road
Default will a 700r4 interchange with a 4l60e
i have a 92 k5 4x4 and the tranny finally gave out on me the other night. and im really not to good when it comes to 4x4's went from a 96 camaro to the blazer. but will a 4l60e out of a 94 jimmy 2wd work on my k5? and if so what changes will need to be made?
Old 10-22-2009, 12:05 PM
Short answer is no.
This is due to the inherent differences between the two transmissions. One is mechanically controlled while the other is electronically controlled. Without the electronic controller for the 4L60E (~$300 last time I looked), the transmission wouldn't know what to do and when to do it.
Your best bet would be to find a 89 or newer 700R4 from another 4wd GM vehicle and swap it in. I say 89 or newer due to the design improvements done to the 700R4 over its life span. The 89-92 700R4's are more reliable than the older ones.
Dark79K5
09-04-2010 09:01 PM
Brokedude
11-12-2008 09:00 PM
fourplayinmi
11-12-2008 08:50 PM
KF4OYP
08-26-2008 03:59 PM
Quick Reply: will a 700r4 interchange with a 4l60e
