just finished tbi to carb swap
Hello , I just finished swapping from tbi ,to a carb. Truck fires up and runs sounds fine. Took for a test drive ,acceleration Sucks almost almost like there's no torch, kinda sounds like the gear on distributor Is a little off when u hit gas while driving ( I remember it doing that before and fixed it with the timing). I took air breather off and found a almost like chocolate milk looking liquid that came from the valve cover hose on driver side that goes in to the original air filter holder .
So anyone have a idea what that could be? It didn't do it till after I took test drive .I almost wonder if it's antifreeze from when I swapped intake or worse.
Sec question if timing is off a little would it cause the sluggish acceleration?
The chocolate milk substance in the air cleaner is caused by insufficient PCV flow. Causes are: Insufficient vacuum to the PCV valve, inoperative PCV valve, sludged up overheads clogging up the oil returns, restricted PCV inlet hose, or a clogged PCV filter. PCV flow brings in filtered air in the air cleaner, travels through a hose to one of the rocker arm covers. Runs down through the oil return holes, through the crankcase, up through the opposite bank oil returns, through the PCV valve, routed to the intake manifold, and burned. The chocolate milk shake is actually blowby gasses and vaporized oil that enter the air cleaner through the PCV inlet line/filter, and condense in the air cleaner. If the PCV system is inoperative, or can't keep up with blowby, the gasses go the wrong way and empty in the air cleaner.
No mention of year on this thing, but the EST wire needs to be disconnected while adjusting timing. If timing is off, performance and fuel mileage will suffer.
1987 k5 ,305 engine , th700r4 Transmission, transfer case is a 208.
I believe I got the timing on point , just the slug to fix now.
Thank you, captain
Check the valve first, make sure it works, and has vacuum to it. If the overheads are sludged up, it makes a HUGE mess cleaning them out. Might want to consider throwing a plastic tarp on the floor before you start.
01LtBlAzEr
01-14-2012 06:52 PM
maverik78
Performance & Brainstorming
04-11-2010 10:05 PM
