low oil pressure
Old 04-24-2014, 02:08 PM
kcurry02's Avatar
kcurry02 is on a distinguished road
Default low oil pressure
Ok so I have a 1999 blazer zr2 4.3l 4x4 with approx. 96,000 miles on it. I just recently(last week) switched it to 5w30 full synthetic Castrol edge. I don't drive it everyday. So yesterday I get about 10 min. down the road. When I stopped at the light my oil pressure dropped to 0psi and the "check gauges" light came on. When I took off the light went off and the pressure went up to 20-30psi. Once I got home I parked it.
Started it up later in the night, the pressure went straight to 40psi and dropped to 20psi when I stopped. After about 10-15min. of driving(to the bank) went inside for 5 min. or less. Came out started it, went to 30psi and 20-30 while driving and dropped to about 5-10psi on stops.
So there's my issue. It appears to be worse during the day(when it's hot).
Any thoughts or suggestions??
Thanks guys and gals.
Old 04-24-2014, 05:37 PM
rockp2's Avatar
Your engine calls for 10W30. 10W has a higher viscosity (resistance to flow) than 5W. I would start there.
As your oil heats up it will thin, hence the lower pressure. Generally in these engines it starts around 40psi when cold and settles about 20psi when warmed up and idling.
Here's a good video also on oil pressure
Old 04-24-2014, 09:26 PM
kcurry02's Avatar
How Oil Pressure Works - EricTheCarGuy - YouTube
Ok thanks. Just downloaded the owners manual on my phone. Didn't realize 5w30 was for colder conditions. Oops. Haha I live in FL. Ok thanks. Will try that and get back with ya.
Old 04-29-2014, 01:44 PM
jay_99z's Avatar
jay_99z is on a distinguished road
Forgive me for asking the obvious...have you checked the level? Low pressure at stops usually indicates low oil. Not talking about a lower pressure at idle but when you see a huge drop down to 0-5 psi and check engine I would guess you are low.
Old 04-30-2014, 06:11 PM
kcurry02's Avatar
haha yea my level is full
musclecar70sfan
09-30-2010 06:58 AM
rohde782
10-08-2009 08:36 PM
Bigblue
10-01-2009 01:43 PM
noom14921992
11-09-2008 05:16 PM
s10_1997
03-28-2008 02:30 PM
Quick Reply: low oil pressure
