engine lope and hard braking
Old 04-28-2008, 06:29 PM
542jerry's Avatar
542jerry is an unknown quantity at this point
Default engine lope and hard braking
I have a '93 s-10 Blazer with 4.3 Vortec. The vehicle has been running fine until the other night. Vehicle started, idledand ran fine, about a mile down the road it started loping real bad. Decided to turn around and head back home that is when I noticed that I had to stand on the brake pedal. Complete loss of power assist. When I arrived back home check engine light on, extreme lope from engine, and still no power assist to brake. Any ideas or suggestions?
Old 04-28-2008, 09:27 PM
Default RE: engine lope and hard braking
Probably a blown vacuum booster. Disconnect the booster line from the front of the booster and plug it. Start the engine. If you looping idle has been fixed, then the booster is mostlikely blown. The next test would be to run it, then shut it down and pull the booster line (with check valve) off the front of the booster. If you do not hear a woosh of air being pulled into the booster, the bladder inside is blown.
Jmooney152
07-18-2011 08:57 PM
caliiangel
06-06-2011 05:32 PM
noseback
02-02-2010 03:15 PM
DBlaser_ca
08-02-2007 04:44 PM
stavendirtbike
07-28-2006 01:58 AM
Quick Reply: engine lope and hard braking
