No Oil Pressure Reading
Maybe, maybe not! What if you don't really have any oil pressure. Check with a test gauge.
Either test it with a real gauge or you might as well put a brick on the accelerator pedal and walk away.
I'd agree with Lesmyer. Before running the engine any more, get a loaner test gauge from the auto parts store and put in place of the oil pressure sensor. Then run your engine and read the test gauge. You don't know which direction to go until you do the things that will be known good (or bad). The test pressure gauge takes all electronics out of the equation and you'll know for sure or not if your oil pump is working. If it is, then you can start addressing a possible cluster or wiring issue. But check the pressure before doing anything more. Very important.
Tuna
05-19-2014 09:08 AM
TheNasty0ne
12-07-2010 03:23 PM
rhaig
11-22-2009 07:28 PM
vaportrail
08-25-2009 09:49 PM
