oil filter adapter removal help...
replacing the oil bypass valve. couldn't get to the bolt to take the oil lines off the oil filter adapter. 2001 blazer 4x4. took bolts out of adapter hoping it would drop down enough to remove the lines. no luck. Do I have to remove the front axle to replace bypass valve and remove lines from adapter???
Kreigeist89
05-12-2013 04:52 PM
