Oil Filters 4wd vs. 2wd
Old 07-10-2008, 12:10 PM
BlazerSS's Avatar
BlazerSS is an unknown quantity at this point
Default Oil Filters 4wd vs. 2wd
Okay I have an interesting question. Is there any harm in using a bigger 4wd oil filter on a 2wd truck? I have used both and haven't seen a difference in oil pressure, etc. but just want to make sure with the experts before I purchase another 4wd filter for my 2wd beast. I figure that since they cost the same, why not get the 4wd one which is longer with more filter media.
thanks
Old 07-10-2008, 12:13 PM
Default RE: Oil Filters 4wd vs. 2wd
If it screws on and seals, it'll work.
I used to use the 4.3L oil filter on my Bonneville with the L67 supercharged 3.8L v6.
Old 07-10-2008, 01:03 PM
rriddle3's Avatar
X2.
I use the larger Wix filter on my 2wd. More media = more filtration.
Old 07-10-2008, 06:56 PM
BlazerSS's Avatar
I wasn't sure if, and forgive my ambiguous description, the threaded oil pressure valve (the cylinder the oil filter threads on to) is longer on a 4wd than a 2wd or not. I guess I was concerned that if it is and I'm using a longer filter on a 2wd truck then the oil isn't circulating and filtering properly and affecting the pressure. Does anyone know for fact by owning both a 2wd & 4wd 4.3L mpfi if the sending cylinders are the same length?
Old 07-10-2008, 07:33 PM
I'm not sure what it is specifically that you are concerned about, but if the filter threads on and the seal, well, seals, then it will work.
TFisher
01-18-2013 02:32 PM
step66
06-09-2012 06:47 PM
gmbwrenchn
06-28-2009 09:57 AM
swartlkk
05-11-2008 09:08 PM
magtec
08-30-2007 06:45 AM
Quick Reply: Oil Filters 4wd vs. 2wd
