03-09-2009, 09:45 AM
Oil Leak
I dont know if this in the right thread or not but here it goes. The Main seal in 2001 S10 Blazer is going bad and so the oil is leaking. It is going to cost me $900 for labor and everything my mechanic said. Have any of you guys had this problem?
03-09-2009, 10:12 AM
Rear main seal most likely. Are you sure that is where it is leaking and not from a loose oil pan? I had what I originally thought was a rear main seal leak on my old Bravada. It turned out that the pan bolts were loose. A good cleaning and torquing them back down and it never leaked again.
03-09-2009, 10:29 AM
Yea i put a special dye into the oil and thats where it was leaking from. I prefer to do everything to my Blazer but i wanted a second opinion from my mechanic who i have had a for a long time and he assured me that it was that
03-09-2009, 10:41 AM
Is the front of your flexplate wet with oil? If it is, then I would agree that the rear main is the cause. If it is not, then the rear main is doing its job properly and the leak is someplace else.
My leak looked EXACTLY like a rear main seal leak until I looked at the front of the flex plate which was dry in my case.
Just trying to save you some time, money, and aggravation.
As far as replacing the rear main seal, you have to pull either the engine, or the transmission. If you have a lift to work with, the transmission will be easier than the engine simply due to the amount of other stuff you have to disconnect/remove when pulling the motor.
03-09-2009, 12:24 PM
I am going to test it one more time today and i will tell you what i find.
03-11-2009, 10:34 PM
I am holding off on getting a new main rear seal and i am going to try this Bars rear main seal repair see if that will stop the leak.
__________________
2001 Chevy
S10 Blazer ZR2
03-11-2009, 11:26 PM
in my 05 blazer my rear main went out at about 30000 miles
__________________
05 xtreme blazer
cold air intake, flows
working on rear mount turbo
03-12-2009, 08:41 AM
Quote:
I cringe whenever I hear people turning to a miracle in a bottle. That stuff will not work on a dynamic seal like the rear main. It is only made to work with static seals like an oil pan or valve cover gasket.
Have you verified that the rear main seal is the cause of the leak? Have you looked to see if there is oil on the front of the flex plate?
03-12-2009, 03:13 PM
Yes i have and it did have oil on it. I know i am taking a chance with the sealant but i thought id try it anyway.
__________________
2001 Chevy
S10 Blazer ZR2
03-12-2009, 03:22 PM
Ok. I was just trying to make sure that it has been verified as the issue. Too many times a loose or leaking pan gasket has been mistaken as a rear main seal leak and people have been soaked by a dishonest mechanic who just tightened a pan or replaced a pan gasket while charging for a rear main seal change.
Tags
2001, bars, blazer, chev, chevy, cost, fix, front, leak, leaks, main, motor, oil, rear, repair, seal  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
