Oxygen sensors ( How many and where ? )
Old 06-03-2011, 02:25 AM
Supercity's Avatar
Supercity is on a distinguished road
Default Oxygen sensors ( How many and where ? )
Hello,
I have intermittent oxygen sensor error codes :
System Too Lean (Bank 1)
System Too Lean (Bank 2)
On a 4.3l V6 Vortec Blazer 4X4 4 doors year 2000 :
1 - How many Oxygene sensors are there ?
2 - Do you know their OEM (chevrolet) references ? To order the parts
3 - Are they differents ?
4 - Where are there exactly located ?
5 - Where is exactly located the MAF sensor ?
6 - Do you know the reference chevrolet of the MAF sensor to order ?
7 - Where are specialy the oxygen sensors bank 1 and 2 ?
Many thanks for you help and your comments.
Regards.
Supercity.
Old 06-03-2011, 06:52 PM
mykeboy01's Avatar
mykeboy01 is on a distinguished road
There are three oxygen sensors on the Blazer:
1) Driver side downpipe, near the wheel well.
2) Passenger side Y pipe, right before the catalytic converter
3) Right before the muffler, between the Cat. and Muffler.
Bank 1 is the driver side sensor, and Bank 2 is the passenger side one.
From numerous sources, including this forum (swartlkk), you don't need to replace the one south of the cat, unless of course, you are throwing a code for it. Save yourself the Fifty Dollars (American)!!!
As for reference #...? I just replaced mine w/ Bosch #O2S-1948. It is a universal part...just look for a heated, 4 wire replacement. Bosch or AC Delco will do (depends on availability). All three are the same!!!
Your Mass Airflow Sensor is the metal piece on your intake between your airbox filter, and your throttle body. If you need to clean it, remove it from the intake, take the torqs screws out, sink the two parts in a big ziploc baggie filled with rubbing alcohol. Let it sit for an hour, take it out, place it on a towel. GENTLY, with a Q-Tip ear swab, clean the platnum connectors. They are Brittle!!!
You aren't throwing a MAF code...You probably don't have to order a new MAF sensor...cleaning it ever so often usually does the job!!! Plus, they are like 200 dollars + !!!
Old 06-04-2011, 06:56 PM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
as for cleaning the MAF get some approved cleaner for it, seen to many get recked from using incorrect cleaner and damaging it
this is what i use
CRC Mass Air Flow Sensor Cleaner (11 oz.) - CRC05110
Old 06-06-2011, 02:20 AM
Supercity's Avatar
Hello,
Many thanks for your comments.
I will order and implement accordingly.
Regards.
Supercity.
Old 06-22-2011, 08:48 PM
CRDuncan's Avatar
CRDuncan is on a distinguished road
Great information my error is bank 2 sensor 1. There are two sensors on bank two so which one is number one and which is number two?
Old 06-22-2011, 08:52 PM
Vehicle info?? Regardless, the one closest to the engine on the passenger side is B2S1. The one further back is B1S2 or possibly B1S3 depending on the year.
Old 07-10-2011, 01:23 PM
DaddysBlazer's Avatar
DaddysBlazer is an unknown quantity at this point
You said,The one on the driver side throws the code then replace it? doesnt that mean your cat is clogged or something? If you had the cat cut out will that fix the bank one senser
melstal
03-31-2015 05:08 PM
drin
04-26-2010 02:10 PM
kbreck
03-25-2008 08:57 AM
KA3AX
05-09-2006 08:38 PM
swartlkk
04-24-2006 02:37 PM
Quick Reply: Oxygen sensors ( How many and where ? )
