problems with transmission on chevrolet blazer 1994 5.7 v8
hi please can anyone help me what oil type come in to transmission on chevrolet blazer 1994 5.7 v8 also I need how oil filter for trans looks like.
Best regards,
Ivan Zambelic
Best regards,
Ivan Zambelic
Auto = Dexron III or newer equivalent
Manual = depends... There were two transmissions offered from my references show. The NVG3500 (5LM60) uses Synchro-Mesh Trans Fluid T2850 while the NVG4500 uses Castrol Syntrog GL-4.
thanks for fast replay,
the transmission isautomatic , alsowhat is thequantityinside pls.
bestregards,
ivan
bestregards,
ivan
~6qtrs with a pan drop. A little under 12qts if the transmission is bone dry like after a rebuild with a new torque converter. If you were going to do a flush, you'll need 15-17qts depending on how clean you want the fluid to be.
scottsleazk
03-12-2015 03:36 PM
bertrenolds
02-17-2011 04:05 PM
TimsR1
11-15-2010 08:53 PM
espencars
08-16-2010 06:55 AM
