what have i done
what have i done
i have an 91 4dr 4.3 2wd blazer and i was changing the rotorbutton distributer cap and when i was screwing it down i accidently turned the distributer and now it wont crank the spark plugs have the right gap and the plugs are in the correct place on the cap it acts like it wants to crank but wont turn over please help im desperate to get it back running asap
RE: what have i done
[hr]did you try to get piston to tdc and have the cap on the right firing posision
If you know which way the distributer turned rotate it back the other direction slightly and you should be able to get it close enough in time to start and adjust for the best idle if you do not have a timing light.
you shouldnt be able to turn the distributor unless it was really loose. Are you SURE you go the plugs on right?
the Fireing order would be my best guess....i just went through all this not to long ago....a pain in the butt.
Regardless of firing order or how far off the distributor is, cranking should not be impacted. Becareful when rotating the distributor to get it back to the correct location, a little movement can mean a lot.
Try looking at the base of the distributor where the clamp is, unless your engine is exceptionally clean you will be able to tell where it was.
When you get it correctly timed take a chisel and set it across the distributor base on the engine and on the distributor boss on the block and give it a wack. You now have an alignment mark that is close enough to start any engine even after you pull the distributor, as long as you do not rotate the engine.
David
David
good news got it fix the dist. was advanced to far the i had to get the #1 piston to tdc the rotate the dist. to the #1 piston the it fired right up it backfired for an minute until i got the degree right on dist. but im back on the road again
I am glad that it was that simple. (Relatively Speaking) You never know when something strange will happen right out of the blue. I had a car that I pulled in my drive way to change the oil and it would not start again. The engine jumped time on me and I had to have a new timing chain installed. (This was a 1973 Duster I had while going to college)
xAnarChisTx
04-17-2010 06:16 AM
butters
11-17-2009 07:21 PM
havrelm1
23
04-10-2008 09:03 PM
