Radiator help?
Radiator help?
I was replacing a transmission cooling line on a neighbors 2005 Trailblazer. I removed the 3/8" fitting from the radiator on the lower drivers side because it was damaged. The fitting had a beveled washer attached to it. The local parts stores had only the straight fittings with no beveled washer. I went to put one on and the piece that it threads in to went inside the radiator and coolant came pouring out. I put the old "beveled" fitting back on temporarily and all seems well. I guess my question is: Did I ruin his radiator? I see the purpose of the beveled washer, but is it normal for that piece to be pushed in to the radiator?
Thank you for any insight you can offer.
bigdaddykane93
01-04-2010 12:03 PM
afrench690
15
04-17-2008 05:46 PM
Maldo15d
12-04-2007 08:00 PM
