removing the front drive shaft on Bravada
I have a 94 Bravada just a putt around truck back and for the to work and short runs no family road trips, well just got the news that the front differential is messed up thinking of unhooking the front drive shaft and just leaving it be 2wd ?
Your truck is equipped with BW4472 transfer case that splits the torque between the front and rear axle, 35%/65%. It is a fluid coupling transfer case which has no physical connection between the transfer case input shaft and the rear output shaft. As such, there is no 2wd mode. If you disconnect the front driveshaft, you will burn up the transfer case and likely go no where in the process.
removing the transfer case
Razmear
14
02-10-2018 01:06 PM
Chevy33
01-20-2011 12:03 AM
street101
10-29-2010 04:17 AM
drodr05
09-24-2010 02:15 PM
lizzj70
06-23-2010 06:57 PM
