rough idle in gear at stop
2000 Chevy blazer LS 2 door 4x4 Vin w. I have replaced MAF ,vacuum lines, cap and rotor, plugs and wires, pcv, ignition coil, fuel filter, cleaned egr and throttle body, checked for leaks around tb housing, vacuum is good, fuel pressure good, and the CEL is not on. I've also replaced air filter. Blazer runs great on hwy but when I stop it idles rough up and down and occasionally dies which is not often. When I unplug MAF it holds steady idle. Any suggestions greatly appreciated.
dannyb91979
07-16-2013 06:08 PM
clicheche
03-24-2013 09:17 AM
ktfr4
04-08-2007 11:14 PM
