Rough idle, squalling noise when accelerating, and rpm loss - Blazer Forum - Chevy Blazer Forums
Search
Search
Reply
LinkBack Thread Tools Search this Thread
Old 01-11-2017, 04:09 PM
MichaelC is on a distinguished road
Default Rough idle, squalling noise when accelerating, and rpm loss
I have a 2002 blazer xtreme, with the 4.3 V6 Vortech engine. About a week ago it started idling really rough and didn't really act like it wanted to go from a stop, it seems as if a single cylinder is misfiring, which is why some suggestions people have made don't make sense to me such as certain sensors or the fuel filter because wouldn't these effect the whole engine and not a single cylinder, I may be wrong about this but if you have one of these suggestions could you please explain it to me? The idle is worse in gear than it is in park. At high revs it would clear up, however when I press the gas pedal the engine makes a squalling noise and we were unable to determine where exactly it was coming fron. The past couple days it has been dropping in rpm while I'm driving around 65+, this feels as if the brakes is being lightly tapped while I'm driving. Also it doesn't seem as if the car wants to accelerate at times until I press the gas pedal down pretty hard then I will have an rpm spike and then the car will accelerate. Gas mileage is also worse then normal. I did a tune up with wires, plugs, cap, and rotor. Changed the fuel injection spider. Changed pcv valve and cleaned MAF sensor. Ignition coil was changed as well. Oil and transmission fluid and filters were changed a couple months ago and are not out of date. Air filter isnt clogged. Throttle body looks fine however my gas pedal doesn't feel exactly smooth when pressed down anymore. Issue does not change with heat or air on, and it also doesn't change whether radio is on or not and doesn't cause the radio to lose power. Check engine light is on but has been almost since the time the car was purchased new, however it does flash now when accelerating, it doesn't flash a certain number of times, it just flashes continuously while gas pedal is pressed. I have not been able to find a solution to this anywhere and it has quickly become somewhat expensive for me. I believe this is everything I can think of at the moment.
Reply
Thread Thread Starter Forum Replies Last Post
Low Idle/rpm rough/shaky engine, high rpm feels normalish Naydog101 2nd Gen S-series (1995-2005) Tech 3 11-14-2016 10:50 PM
Rough idle, loss of power and check guage light csmith85 Engine & Transmission 1 05-16-2011 11:13 AM
95 4x4 4.3 REV LIMITS at 4000 rpm while Accelerating dutchman31 2nd Gen S-series (1995-2005) Tech 6 05-04-2011 10:09 PM
1991 S-10 Blazer, 4.3l TBI, 4x4: sudden loss of power and stalling when accelerating ruralite85 1st Gen S-series (1983-1994) Tech 8 03-31-2011 09:17 PM
95 blazer rough idle and loss of power ryn9909 Engine & Transmission 7 07-21-2008 06:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
