Runing Rough
Runing Rough
Hey guys i need some help i have a 1997 blazer 4.3l vortec its running real rough at idle and i dont think im getting all the power i should at speed i have change plugs, wires, cap, rotor, air filter, and heat temp sensor all thinkn this might be the problem and i have also ran seafoam thru here for a couple of tanks ( she had been sitting for about 6 months ) any help would be grestly appreciated im stumped
Runing Rough
Did you have ever check you fuel and filter pump?, I haved a similar problem and when I change both I get more miles per galon and more power from my engine.
do you know the condition from you sparkplugs?
I hope this help
I hope this help
What brand of pump did you put in? Any brand besides AC Delco or Delphi are known to have a common issue of failing. Regardless of the brand of fuel pump...you still should do a fuel leakdown test. It could be a pressure regulator or injectors or other things. The leakdown test will either rule fuel delivery out or start you in the right direction. Also, is there any SES codes?
Im getting a cylinder 6 misfire code and one shop says its the injectors and one says its air related like a MAF sensor or something the shop that says its the injectors ran the codes and said yea its injectors knowing its the most labor intensive the other place says its running to rich which wouldnt be injectors ???
Any cylinder misfire can be caused by a fuel delivery issue as well as other things. You can also pull the MAF off and clean it with MAF spray. Be careful not touch the little wire or break it.
RandyRhoadsFan82
03-29-2014 11:22 AM
blazerguy22
11-14-2013 11:50 PM
