tcc solenoid wiring??
how do you unwire the tcc solenoid? mine does not have a connector, its wired directly into/through the wiring harness. this is the same on both,1 piece case and a 2 piece 4l60e's i have. do you have to pull the wires out of the solenoid or do you have to make a splice with but connectors inside the transmission?
96 blazer 4.3 w 4x4, two piece transmission case/replaced with a one piece trans
Why are you trying to disconnect the TCC?
If you are trying to remove the wiring harness, you need to disconnect it on the outside of the transmission and push it back into the pan area.
If you are wanting to replace it, then yes, you make connections inside the transmission pan.
igs4dragon8
04-02-2013 01:48 AM
2000, 98, blazer, brake, disconnect, harness, installation, located, location, silenoid, solenoid, switch, tcc, transmission, wiring
