96 blazer no start please help trying to work on it friday night asap
Old 01-31-2008, 10:05 PM
Ridinblazer's Avatar
Ridinblazer is an unknown quantity at this point
Default 96 blazer no start please help trying to work on it friday night asap
Hello everyone i have a 96 blazer, it has a hard start problem, it first started off as really har dstarting just crnking it over then i turned the key on and off till i heard the fuel pump kick on kinda of like a primeing thing, if i shoot a shot of ether down the throttle body it will start, once it starts sometimes it would bog down until it stalled and i noticed the converter was starting to get red and i could smell sulfur so i replaced the o sensor and converter, i also replaced the cap, rotor, wires, coil, when i crank it once the fuel pressure only goes to 45-48lbs if i keep cranking it it goes to ablut 50-52 sometimes its goes to 60lbs when it goes to 60 it kinda starts so i am wonder do i need a fuel pump or what please help thanks i am trying to work on friday night so any hints will help
Old 01-31-2008, 10:09 PM
hillbillyinOhio's Avatar
Default RE: 96 blazer no start please help trying to work on it friday night asap
locked to be deleted.
93S10TahoeLT
62
11-16-2015 08:13 AM
chevyman4L
10-20-2008 09:58 AM
Ridinblazer
48
08-12-2008 10:35 PM
Ridinblazer
01-31-2008 10:08 PM
dirtyzr2
08-26-2006 07:03 PM
Quick Reply: 96 blazer no start please help trying to work on it friday night asap
