Trans pan fluid capacity ?? - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 01-31-2008, 08:54 AM
TAZ454 is an unknown quantity at this point
Default Trans pan fluid capacity ??
How many quarts of trans fluid does a pan hold ?? What can happen if you over fill by a quart ?? What trans does a 2wd 98 Blazer have 200r ,700r, ??
Old 01-31-2008, 09:28 AM
rriddle3's Avatar
Default RE: Trans pan fluid capacity ??
I believe you will dump about 5 quarts out of the pan. If you over fill, the fluid will get frothy, might leak out from the dipstick tube. The excess pressure from overfilling could possibly damage the tranny. The '98 uses the 4L60E auto transmission.
Old 01-31-2008, 06:30 PM
Over filling isn't too much of a problem, it will leak out the vent hose.
The vent hose is on totp of the tranny right behind the bellhousing. you have to reach up to find it, although on some models GM put a 8" length of black hose on it so it hangs lower.
If it were my truck and I drained the pan, I would add in 4 quarts. Fire up the engine and check the dipstick. Shut the engine off and add 1/4 quart at a time until you see it on the dipstick. Repeat until full. then take it for a 20 minute test drive and check it again, and check for leaks.
It takes 1/4 quart to go from the bottom of the cross hatch area on the dipstick to the top of the cross hatch area.
Old 02-01-2008, 03:57 AM
Chevy Lover is a jewel in the roughChevy Lover is a jewel in the roughChevy Lover is a jewel in the rough
Quote:
ORIGINAL: TAZ454
You should have a 4L60E transmission that takes 5 quarts when you drain the pan.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Changing trans fluid and installing deep pan ComputerNerdBD Engine & Transmission 11 01-30-2011 02:13 PM
fluid capacity irondooks88 Engine & Transmission 0 06-21-2010 04:58 AM
Power Steering Fluid Capacity? republic Steering, Suspension & Drivetrain 2 10-12-2009 05:58 PM
700R4 fluid capacity? corr33 Engine & Transmission 1 10-31-2007 07:59 PM
NP-208 fluid capacity KennyJonson Full Size K5 Tech 7 12-26-2006 07:09 AM
Tags
01, 2002, 43, 700r, 96, 98, blazer, capacities, capacity, chevy, filuid, fluid, oil, quarts, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
