Transmission Vent Tube Pinched Shut?
Good Evening -
I have a question about a 4L60E Transmission out of a 99 4x4 blazer. The code on it indicates it is a 98 transmission. We are putting in a 00 blazer. Supposedly the 99 blazer transmission has been rebuilt. It seems likely based on the markings on the case, however one thing we ran into is that the vent tube on top of the transmission has been pinched shut (seems to have been intentional).
My question is this: Is there any reason that would make sense why this was done? Our plan is to cut the end so it is open again and clamp the vacuum hose to it.
Just looking for any of you tranny experts out there to chime in.
Thanks in advance.
Thanks in advance.
However, you are correct, if the vent tube is plugged, the fluid will blow out of the transmission one way or another. The pressure will find a way out.
v8vairman
04-12-2006 01:43 PM
