In-vehicle rod bearing replacement - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 09-14-2010, 09:47 AM
blazercruzer is on a distinguished road
Default In-vehicle rod bearing replacement
Tip of the hat to everyone for their excellent posts. Many of them are very informative.
I'm going to change out the rod bearings in my '96 Blazer with the engine still in place. Does anyone have any tips or suggestions? Once I get the front t-case removed it appears to be clear for operation.
Old 09-15-2010, 12:07 PM
Thor_449 is an unknown quantity at this point
Don't put the connecting rod cap on backwards, remember to locktite and torque the cap nuts to specs, dont bang on it with a hammer too hard, mike everything, plastic gauge the bearing to make sure you have enough oil clearence
Old 09-16-2010, 10:18 AM
Thanks for the reply Thor... I'll be tackling this over the weekend. I don't have much run time since the rod knock started (maybe 20min. or so), hopefully there's no further damage. It appears I could even remove the crank from under there if need be. I'll be sure to remember to scratch on the cap number while I remove them. Here's the crankshaft and rod bearing specs from the factory service manual.
Old 09-17-2010, 02:05 AM
old skool luvr's Avatar
that's "mic" everything Thor. as in micrometer.
unless you're getting "Mike" to do all the work.
sorry, been a long day (and i'm a machinist by trade), so i'm just gonna go now........................
Closed Thread
Thread Thread Starter Forum Replies Last Post
Rod Bearing vs Main Bearing brianp Engine & Transmission 4 08-11-2014 05:16 PM
determing rod bearing replacement size 3D_Illustrator 2nd Gen S-series (1995-2005) Tech 1 07-21-2013 08:24 AM
Rod bearing replacement without engine removal? seriosbrad 2nd Gen S-series (1995-2005) Tech 2 04-23-2013 10:24 PM
Tie rod to track rod seems loose Klturi421 2nd Gen S-series (1995-2005) Tech 1 08-02-2011 08:21 PM
In-vehicle main/rod bearing change TZFBird Engine & Transmission 5 01-20-2011 11:17 PM
Tags
1996, 62, 99, bearing, blazer, cap, changing, chevy, connecting, isuzu, jimmy, remove, replace, replacement, rod, suburban, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
