White Smoke
White Smoke
Hello All!
So I currently have a 2001 Chevy Blazer Xtreme 2WD & it started to overheat & throw out white smoke on the passengers side. The temperature gauge isn't working & it has coolant, so I have no idea what's going on. I recently changed the radiator & added a thermostat (didn't have one originally).
Any ideas? Thanks.
Any ideas? Thanks.
plus one on the white smoke being coolant. If you have the thermostat installed correctly, the first thing I would do would be a cooling system pressure test. Are you/were you ever running dexcool?
vernoninmd
02-24-2008 11:52 AM
