87 full size k5 shaking and vibrating
Old 06-06-2011, 06:16 PM
jake2011's Avatar
jake2011 is on a distinguished road
Default 87 full size k5 shaking and vibrating
i have an 87 k5 when i take off it shakes and vibrates at around 25 to 45 then stops. it also squels when taking off, i have jaked up the front end and tryed moving tire with no movement. what can i check and do to fix the problem i am out of ideas. thanks.
Old 06-06-2011, 06:20 PM
jake2011's Avatar
also when i drive it around the block the passenger side hub is hot to the touch , and i mean hot not just warm but hot to where you dont want to touch it, i need help please.
Old 06-06-2011, 07:25 PM
abig84's Avatar
is it a fast vibration or slow, like does it shake with the speed of the tires? ive had alot of issues with k5 blazers in the past with death wobble due to having bigger tires. if one side is hot and the other is not. and theres no play up down or side to side, might be a good idea to disassemble the bearings and repack them with grease. ive stripped k5s before where the axles were bone dry
Old 08-19-2011, 12:53 AM
gadyck@hotmail.com's Avatar
gadyck@hotmail.com is on a distinguished road
ball joints
admathi
12-15-2019 04:24 PM
goerzenl
11-01-2010 10:14 PM
blacer2000
09-02-2010 07:41 PM
troyky29
02-08-2009 03:36 PM
Dturner14
06-30-2007 11:32 PM
Quick Reply: 87 full size k5 shaking and vibrating
