89 blazer steering column loose - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 01-25-2011, 05:53 PM
goerzenl is on a distinguished road
Default 89 blazer steering column loose
my steering column is loose right where the tilt joint is. can this be fixed or do i need to try and find a hole new steeering column. please help.
Old 01-25-2011, 06:33 PM
81Z4ME is on a distinguished road
If the Blazer steering column is put together like an 86 IROC steering wheel there are 4 bolts right below that "joint" that work loose. The take a special socket to tighten up and that's after you remove the steering wheel, air bag (if your blazer has one), turn signal switch, etc. There's a bunch of stuff in there to remove before you can get access to those 4 bolts with an extension and socket. The bolt heads look like the tip of a torx head screw driver. I don't remember where I bought my socket set from but you can buy the sockets.
I made up my mind after I got mine back together that the next time that happened (if there is a next time) I'll just go to a junkyard and get a whole other steering column, it was that big of a PITA.
Good luck with yours, whichever way you go.
Old 01-25-2011, 07:06 PM
mr.vls will become famous soon enough
Do a google search on GM tilt column and you will find a few good write ups. I had the same issue and thought about tackling this job myself but I stopped by my idependent shop and they were really familiar with the symptom and repair. Basicly, they take the column apart to get at the mounting bolts remove them add locktight and reassemble. They charged me an hours worth of labor. My column is nice and tight now.
Below is one of the links that gives the repair procedure.
http://www.gnttype.org/techarea/susp..._steering.html
Old 01-25-2011, 08:02 PM
abig84's Avatar
did a few on my trucks. alot of write ups i see only talk about getting at the first two bolts which is easier cause you dont have to take apart alot of stuff. i just pulled the two out, lock tighted them and put them back in... years later they all still work fine
Old 01-25-2011, 10:16 PM
thanks for all the info i will let ya know what i do.
Old 01-26-2011, 09:44 AM
I bellieve the shop that did mine did two of the three bolts. I can not tell any differance as my steering wheel is nice and tight.
Old 01-26-2011, 06:15 PM
local shop said they can do it for 80 so i think ill let them deal with the head for that price lol
Old 02-07-2011, 10:06 AM
Did you ever get your steering column worked on?
Old 02-07-2011, 11:12 AM
IrvJr is on a distinguished road
I have done it a couple times and it isnt too bad, just tedious. First time just did the 2 that were easily reached, then it happened again and i took it all the way down and loctited the **** out of them.
Old 02-14-2011, 06:44 PM
yea i got it fixed at a local shop for 80. for that price i figured they could deal with the head ach lol.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Column Shifter loose/not engaging Dirsuper Full Size K5 Tech 5 06-29-2013 11:44 AM
74 K5 loose steering and wobbly steering wheel litterbug Steering, Suspension & Drivetrain 4 10-19-2011 07:50 AM
Tail gate issues. Loose lock, Loose cable. ussexplorer 1st Gen S-series (1983-1994) Tech 2 04-11-2010 06:53 PM
Help me replace steering column 89 blazer Jays00XJ 1st Gen S-series (1983-1994) Tech 2 11-24-2009 09:08 PM
Loose Steering Column ghost Steering, Suspension & Drivetrain 2 06-06-2009 12:50 PM
Tags
1989, 81, 89, 91, 93, blazer, chevy, column, disassemble, loose, removal, removing, repair, steering, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
