Any tips or tricks for heater core problems?
My Blazer has no heat. It just blows cool air no matter how long it's been running. The motor gets warm, so do the hoses to the heater. But, my temp gauge only reads 100deg when running and maybe 150deg after you turn it off. It has an aftermarket 350 and runs like it's supposed to. So I am going to flush the heater core out but wondered if it could be something else? I already flushed out the radiator and block, and changed out the tstat (195deg).
if both hoses going to the heatercore are hot then it may be a blend door issue. i just worked on a ford that wasnt getting any heat, it had one hot hose to the heatercore and the other was barely worm, i flushed it out and it worked fine, im think it just had a air pocket in it cause when i pulled the lines off no water came out.
That's maybe what's wrong with mine. Now that you mention it. one hose was hot and the other wasn't as hot, it was just really warm. But they were not the same temp. I'm going to flush those hoses and the heater core out tomorrow, thanks! now to just figure out why the temp gauge only reads 100deg when running. Any thoughts?
So...I figured it out! I should take pics, but the two heater hoses were in the wrong places! One was going to the water pump (correct) but the other one was going to the radiator (incorrect). I put that one to the intake manifold and problem solved! The thing heats up perfectly! It's running great now.
ldkronos
12-13-2007 03:54 PM
Blue Vette
11-12-2007 09:56 AM
arbowman
10-17-2006 04:39 AM
