leaky tranfer case?
Old 08-13-2010, 06:51 AM
rbesaw's Avatar
rbesaw is on a distinguished road
Default leaky tranfer case?
i have 1986 former army blazer, seems to be throwing oil out of the rear of the transfer case, have changed the rear seal twice. can't seem to see were the leak is coming from can anyone help?
Old 08-13-2010, 09:43 AM
What transfer case does it have (aluminum case is likely to be an NP208, cast iron case could be an NP203 or NP205)?
You could have a leak around the speedo output, the rear seal, around the splines inside the rear yoke, the rear output housing mating surface to the main t-case body, etc... I would clean things up really well and then determine where the oil is coming from.
Keep the t-case topped up!
Old 08-13-2010, 10:04 PM
rroeder96's Avatar
rroeder96 is on a distinguished road
while on the subject of transfer cases can you tell me what type of fluid to use on an 85 k10 4wd for the transfer case this is my first 4wd so i want to do everything i can to take care of it thanks....
Old 08-14-2010, 04:41 PM
Loosely related... It really comes down to what transfer case you have. The newer aluminum bodied transfer cases came factory filled with ATF. The NP205 used 80w90 gear oil when originally released, but somewhere in the mid-80's GM changed them to ATF. I can't find it now, but I have seen that using ATF is better for efficiency (mileage), but there is a significant difference in the bearing life when compared with 80w90 gear oil. The NP203 uses 10w30 or 10w40 engine oil as gear oil would kill the pump inside the transfer case.
Old 08-14-2010, 04:56 PM
abig84's Avatar
if its the military blazer and its the factory case itll be a np208. if its still leaking out of the seal itself after changing, im in the same boat. ive changed mine 3 times and it still leaks. i dont know if the driveshaft is slightly pitted or what but i just basically got to live with it
Old 08-14-2010, 09:43 PM
rroeder96's Avatar
mine is the np208 from what i read about it takes atf but i was just making sure thanks
rob1621
02-07-2009 11:51 AM
Blazin_1t_up
15
09-08-2008 11:45 PM
huds
12-02-2007 08:37 PM
timmytenspeed
11-22-2007 12:39 AM
KiddBlazer1983
05-29-2006 12:59 PM
Quick Reply: leaky tranfer case?
