Belt Diagram
Belt Diagram
i have a 1990 GMC Jimmy with a 350. PS, WateR pump, Crank, fan, AC, ALT. I was wondering if some one has a diagram on how the belt should go on. I have looked on gogle cant really find the one that has the same set up as i do.
Thanks
Thanks
There should be a diagram under the hood...
providing the sticker is still there and readable. Although, it's not too hard too figure out on your own. Pullies with grooves get the side of the belt with groves. Smooth pullies get the smooth part of the belt.
Pick the closest:
Ignore the red marks
But you dont really need a diagram once you note two givens
1. the relationship of the wrap from crank to fan pulley is always the same.. belt wraps up from driver side of crank around pass side of fan pulley.
2. You never need put belt 'over the fan'
- start from pass side, make loop of belt, put loop around crank pulley first then wrap back of belt around water pump pulley to lowest pulley on driver side.
From then on, easy. Back of belt always UNDER a smooth pulley
jaystoy
05-16-2013 04:38 PM
lionel2
09-07-2012 02:45 PM
RWCastor
06-01-2011 08:14 AM
abig84
12-31-2009 05:40 PM
