compression issue
Old 06-01-2013, 09:49 AM
aro_chase99's Avatar
aro_chase99 is on a distinguished road
Default compression issue
so my truck (88 k5 blazer 350 4 spd 4x4) would idle but bog out and die under load. I did a compression test and found the no. 2 cylinder had 0 psi. I took off the valve cover and it seemed one rocker arm was way to tight, I backed it off and bam have compression but now the truck wont crank over to idle, if it does it quickly dies. spray carb cleaner it trys a little harder to start but still nothing, could it be possible that now that all cylinders have compression its not getting enough fuel, unfortantly no where around here have a pressure tester for TBI's. could the push rod be bent ?
Gimmper
11-11-2012 08:56 AM
bigdaddykane93
01-23-2010 02:10 PM
Jackal
Engine & Internal
36
02-28-2007 10:03 AM
m00nwater
02-27-2006 01:34 PM
93LT
01-16-2006 09:36 PM
Quick Reply: compression issue
