few questions about air cleaner
Old 01-22-2013, 09:31 AM
yarinzim's Avatar
yarinzim is on a distinguished road
Default few questions about air cleaner
Hi Guys,
I'm looking to purchase an air filter for my blazer 90' (TBI), however the task is difficult than i would imagine.
1. first of all I'm not sure which base i need - dropped, raised, off-set or flat. all i want is to buy a one that fits and won't cause clearance problems.
2. i'm trying to keep in mind that i do offroad with the truck so it's important for me to buy a high quality filter. i heard good things about k&n, can anyone confirm based on personal experience?
3. i have some concerns about the fitment, first i see bases that fits a 5-1/8 single 2 barrel, single 4 barrel etc... i understand this measurements refer to carbs, so how can i be sure it will fit my TBI?
the second concern about the fitment is the height, i would like to purchase a 5" tall filter, can anyone please confirm it will fit? or should i just go with a 3"?
in addition, any recommended chrome sets / kits that will fit all the above would be highly appreciated
thanks in advance, yarin.
Old 01-22-2013, 11:03 AM
neo71665's Avatar
I have a 10 inch chrome eldebrock on mine. It fit the factory replacement k&n I already had. Mine is 2 inches tall. I know with my body lift I could fit way taller but on a factory truck I would check, honestly I don't think the room is there for a 5 inch cleaner. Easiest way to check is to get some playdoh. Make a tower and sit it on your breather, close the hood. The hood will squash it down and after measuring you can find out what room ya got.
I don't think any drop bases will fit a s-series but our tbi have standard 4 barrel carb top so any breather with that opening fits.
Old 01-22-2013, 01:44 PM
70-K5's Avatar
70-K5 is on a distinguished road
Plenty of room under the hood of a K5:
Be safe and use a flat bottom plate.
Get out your tape measure and see how much room you have.
3" IMHO is plenty of air cleaner.
Old 01-22-2013, 05:28 PM
neo71665's Avatar
Yeah gotta start looking at sections. Used to people calling them k5 or tahoe. We only call the mini ones blazers.
In my old k5 I actually stacked 2 paper filters and drove it like that so yeah plenty of room on it.
Old 01-23-2013, 12:03 AM
yarinzim's Avatar
there's no mix up here, right guys? were talking about k5
the cleaner in the pic is 5" or 3"?
i looked at this 5" filter 60-1270 - K&N Custom Assemblies, Custom Assembly direct from K&N
and this 3" 63-1007-1 - K&N 63 Series Aircharger Kits, Performance Intake Kit direct from K&N
any good?
Old 01-23-2013, 10:08 AM
70-K5's Avatar
3"
You're options are very expensive. Try Summit racing. The exact same filter element which is what you want is only $53.95.
Air cleaner tops and bottoms are very simple.
Buy this bottom for $14.95:
Billet Specialties Flat Air Cleaner Bases RP1508 - SummitRacing.com
Then choose whatever 14" lid you want. They will all work.
Air Cleaner Tops - SummitRacing.com
Old 01-23-2013, 10:10 AM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
you can get a spectre round filter with chrome housing for like 30 bucks. i think its 14". I had one on my old truck and worked fine.
Old 01-23-2013, 01:27 PM
yarinzim's Avatar
ok i decided to go with JEGS base and top:
JEGS Performance Products 50033 JEGS Performance Chrome Air Cleaners
JEGS Performance Products 50035 JEGS Performance Chrome Air Cleaners
and a k&n 5" filter
K&N E-3760 K&N X-Stream Air Flow Filter Assemblies, Tops and Elements
now the only thing left is a long enough stud kit for my TBI, which has a little offset, not straight... couldn't find one that I'm positive that will fit, any help would be appreciated ...
i saw this one: http://www.jegs.com/i/Spectre/865/4215/10002/-1 but i have a feeling it won't fit, doesn't seem long enough...
Old 01-23-2013, 01:58 PM
neo71665's Avatar
I'd weld a piece of all thread on top of the stud you have now then cut it to fit.
If nothing else get a deep nut that fits the stud and cut a piece of allthread to fit that. Loctite the stud, allthread, and deep nut so it won't come apart when ya take the wing nut off the breather.
Old 01-23-2013, 02:04 PM
yarinzim's Avatar
still struggling between 3" and 5"... i measured, seems like it's gonna fit, but i'm not sure...
Quick Reply: few questions about air cleaner
