flywheel
Old 11-09-2007, 10:39 AM
tom1337's Avatar
tom1337 is an unknown quantity at this point
Default flywheel
'90 full size
Is there any way to tell how many teeth (168 or 153)my flywheel has without removing the shield?
Old 11-09-2007, 01:31 PM
Default RE: flywheel
The 153 tooth flywheel is 12.75" in diameter while the 168 tooth flywheel is 14" in diameter. However that doesn't answer your question... I don't know of any way to tell how large the flywheel is without the cover off...
Old 11-10-2007, 02:10 AM
Chevy Lover's Avatar
You can remove the starter motor, paint a tooth on the flex plate with white paint, then turn the flexplate with a flat blade screwdiver til you reach the painted tooth again. Don't lose count...
Old 11-10-2007, 12:18 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
If it has the original engine, stop by or call any dealer with your VIN and they should be able to tell you, or at least give you a part number which you can have cross-referenced at any parts store. I beleive that all engines with the one-piece real main seal (1987 and up) had the smaller ring gear on the flexplate (153 tooth).
sparky672
01-31-2010 10:17 AM
BlazerSS
Detailing
03-17-2009 10:18 PM
jonesjamesw
04-28-2008 09:55 PM
jonesjamesw
03-28-2008 06:33 PM
mars004
01-22-2007 10:00 AM
Quick Reply: flywheel
