Heater core hoses
VICTORY IS MINE !!! after 3 different taps I was able to get a nipple NOT the quick connect installed in the intake ! put teflon tape on the nipple just in case, but ran the vehicle for an hour and no leaks ! take that GM ! hope you have success junkie ! good luck !
yeah, i kind of forgot to mention that junkie (happens when you're used to doing it yourself). make sure you use some pipe dope, or Teflon tape. the dope will never leak if you use it, but either one will do fine.
Here are the pictures of the connector and hose ( before ) if you have these you are in for a world of fun.
So what do i do if my fitting didn't brake but the threads in the intake are so far beyond being taped. anyone have a remedy?
sadly time for a new intake. or you could try a helicoil. those are used more for spark plug threads on the block that get crossthreaded. but they may work.
but you have to be really careful, it's easy to go too deep & create too large of a hole for the new fitting.
Does anybody have a part number for the nipple that will work with the Vermont American 1/2-14Npt Tap Part Number: 20354?
I was able to unscrew mine without breaking anything (with the hose intact once I gave up on my quick connect tool) but im sure the quick connect will start leaking once I put it all back together.
edit
ok i think i found one from jegs is this the right one?
Chrome Heater Hose Fitting
1/2" NPT x 3/4" I.D. Hose x 2-7/8" Long
Part Number # 555-511111
http://www.jegs.com/i/JEGS/555/511111/10002/-1
edit
That looks like it will do the job nicely.
It looks better than the $3.99 part I got at the local Advance Auto:
http://shop.advanceautoparts.com/web...ci_sku=5707439
It's working great and no leaks, but I wanted chrome :-)
Dorman Heater Hose Connectors Nipple 3/4" Hose x 1/2" NPT x 2-3/4" Long Metal
If I only I could remember to paste in the details...
Yeah, either of those will work!
Those pictures jogged my memory! We had to mess with this very thing on my dad's old '94 K2500 probably 10 years ago. We just ended up using a drill & tap. Dad put back in the same damn thing though...
rza0122
01-03-2011 04:39 AM
ldkronos
12-13-2007 03:54 PM
MudHawg
12-20-2005 12:56 PM
