How do you adjust the idle on a throttle body? - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 10-28-2010, 09:09 AM
Bigguns72's Avatar
Bigguns72 is on a distinguished road
Default How do you adjust the idle on a throttle body?
Have a 1989 K5 Blazer and the idle is a little high. At icy instersections, when stopped, the rear wheels want to push me through. How does one adjust the idle on these throttle bodied units?
Old 10-28-2010, 09:11 AM
It is controlled by the ECU. I would check to make sure that you do not have any broken/cracked/disconnected vacuum lines and that there isn't a gasket leak between the throttle body and the intake manifold (somewhat common problem).
Old 10-28-2010, 11:45 PM
6.2 man is on a distinguished road
Sounds like rear brakes aren't working ?????
Old 10-29-2010, 12:26 AM
69chevelle's Avatar
69chevelle is on a distinguished road
Quote:
agreed, mine did the same untill i redid my rear brakes...
I actually had to put it in neutral to stop, or 4wd(kept hubs locked in the snow).
Old 10-29-2010, 03:11 AM
xmradioguy is an unknown quantity at this point
There is a way to adjust it I will have to search for it and maybe link to another forum if it's ok.
Old 10-29-2010, 03:18 AM
People will argue and say this won't work or you can't do that only the ecm adjusts idle speed, but trust me it does work I have done it to more than 1 tbi and it won't screw anything up. I have done it on my stock 4.3 tbi I have done it on my 5.7 jimmy /holley 670 tbi and lots of others,if you need it I have a pic of where the idle screw is hidden on the tbi's
http://www.thirdgen.org/tpimod2
How do you adjust the idle on a throttle body?-tbi-idle-screw.jpg   How do you adjust the idle on a throttle body?-tbi-idle-cap.jpg
Old 10-29-2010, 06:54 AM
You can change base idle on just about any older setup. However, that is kind of just a bandaid. You haven't really solved the problem...
Old 10-29-2010, 06:12 PM
Well it adjusts the idle speed without the ECM correcting it so yes technically it does solve the problem but like I said some people always argue even if they have never done the procedure.
Old 10-29-2010, 07:52 PM
Assuming there are NO other reasons for the high idle, you would be correct. However, if there is a vacuum leak, adjusting the base idle will not fix the leak.
Closed Thread
Thread Thread Starter Forum Replies Last Post
How do you adjust rocker arms? 2000TAHOEMAN Engine & Transmission 2 01-01-2011 09:27 PM
how do you adjust transfer case shift linkage jacobbuniger Steering, Suspension & Drivetrain 3 12-17-2010 04:08 PM
4.3 high idle how do you adjust it? midnightryder 1st Gen S-series (1983-1994) Tech 2 12-29-2009 03:43 PM
Got no Park. How do you adjust the gear selector cable??? er.rigney 2nd Gen S-series (1995-2005) Tech 1 06-03-2009 10:16 PM
What do you think of this??? 78mm Throttle Body ivannj Engine & Internal 8 09-08-2006 06:46 PM
Tags
96, adjust, adjusting, blazer, body, chevy, full, gmc, idle, jimmy, k5, size, speed, tahoe, tbi, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
