how to install distributor on 1989 350 tbi - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 02-07-2011, 09:33 PM
sirwilliamwagner is on a distinguished road
Default how to install distributor on 1989 350 tbi
hey just was wondering if some one could point in the right direction havent done this one in a long time where im going wrong is the haynes manuals suck they only discribe how to install the old distributor not a brand new one and doesnt offer much help basically the book would make better *** wipe. thanks for your time
Old 02-09-2011, 05:55 PM
Mighty Mouse's Avatar
Mighty Mouse is on a distinguished road
Did you already pull the old one?
Old 02-10-2011, 11:29 AM
yep old one was destroyed and scrapped plus at the same time i took off the heads and rebuilt them. i know the engine has to be at #1 piston tdc combustion, the oil pump shaft has to line up the dizzy and when it seats has to point to the #1 terminal and now its fully installed top d center combustion but there is no fuel getting to the motor its sitting at the injectors, the injectors are fine electrical has been checked all connectors grounds etc now the motor feels like its lacking compression but passed a compression test 100% when heads where removed. now ive got power every where except at the injectors. now just wondering.
Old 02-11-2011, 04:29 PM
Check all the grounds and make sure the fuel pump kicks on when you turn the key to start it.
Old 02-11-2011, 09:00 PM
yeah i checked all grounds connectors they are all connected the fuel pump primes it up to the tbi at 11psi to the regulator , the injectors arnt getting power and there is no spark just wondering what controls it the only thing i found unhooked is a 6 pin connector up under the dash to the top left behind the gauge cluster it has 3 wires on it a black, pink and tan and white the other 3 pins are not used i can find out where it connects too but it does branch of the engine harness other than that the electrical is all connected everything works but no spark and no injector firing
Old 02-11-2011, 09:12 PM
cant*
Old 02-12-2011, 06:15 PM
That connector might be the problem. Try to plug it in first. I'm not exactly sure what it is for though without seeing it. Also make sure the dizzy you installed is good.
Old 02-12-2011, 11:12 PM
yep its brand new so should work fine its from chandler motor sports cant find where the connector goes
Closed Thread
Thread Thread Starter Forum Replies Last Post
1989 s10 4.3 TBI rough idle and surging techboy89 1st Gen S-series (1983-1994) Tech 14 08-28-2013 07:55 PM
87 350 TBI motor swap with built L-48 350 tech180 Full Size K5 Tech 11 02-02-2013 11:23 AM
1989 k5 350 tbi dizzy help sirwilliamwagner Full Size K5 Tech 1 01-30-2011 12:10 AM
1989 4.3 tbi swaped into 1995 4.3 cpi's place chrisw1022 Engine & Transmission 5 11-17-2009 10:34 PM
1989 Chevy 350 red_dog007 Engine & Internal 1 03-11-2008 11:27 PM
Tags
1989, 1990, 1995, 350, 89, checy, chevrolet, chevy, distributor, engine, install, installation, installed, installing, spark, tbi
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
