ignition switch removal - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 01-14-2010, 08:36 PM
fireman11368 is an unknown quantity at this point
Default ignition switch removal
hey im trying to replace the ignition switch on my 89 k5. i tried removing the two nuts holding the column but it doesnt lower. is there another way to get to it or do i need to remove the the steering column? thank you
Old 01-14-2010, 08:43 PM
Banned
Spectreblazer is on a distinguished road
Quote:
i think kyle had a thread on a how to. ill see if i can find it
here it is not sure if it will work for k5 but maybe it will help http://blazerforum.com/forum/showthr...switch+removal
Old 01-14-2010, 10:00 PM
thanks for the info those are instructions for the s10 blazer
Old 01-14-2010, 10:03 PM
That they are...
So what exactly is the problem you are running into? You cannot remove the bolts that hold the ignition switch to the column? If so, you will likely have to drop the column down to get better access to the bolts that hold the ignition switch on.
Old 08-17-2011, 11:42 AM
wy0mn's Avatar
wy0mn is on a distinguished road
Default Bump!
Working on a K5 Blazer.
I have the switch out and replaced, the actuator rods weren't connected to start with, so I can't just reverse the process. Cannot figure out how they attach given the angles bent into the rods (2ea).
The instruction with the replacement switch are gnarly.
Any help (photos preferred) would be uber appreciated.
Lex
Old 08-17-2011, 12:22 PM
I'll see what I can find in my '90 R/V factory service manual when I get home.
Old 08-17-2011, 02:02 PM
wy0mn's Avatar
Thanks man, but I spoke too soon.
Once I took the seat out, so I could get my fat head under there, everything fell into place.
Lex
Old 08-17-2011, 02:58 PM
OK. Good deal! Glad you got it. I may still post up what I find when I get home.
Old 08-26-2011, 11:18 AM
Suncrest Sniper's Avatar
Suncrest Sniper is on a distinguished road
You need to remove the bolts that go into the firewall on any GM steering column to lower it. Once those are out it will give you enough room to drop it down and access the dimmer switch and the ignition switch. I've done tons over the years and unless your doing a complete column rebuild there's no need to pull it from the vehicle.
SS
Closed Thread
Thread Thread Starter Forum Replies Last Post
Ignition Cylinder or Ignition Module Needed? Brian5792 2nd Gen S-series (1995-2005) Tech 2 06-23-2013 10:46 AM
Ignition switch removal 1997~ Help austinlee 2nd Gen S-series (1995-2005) Tech 1 05-08-2010 10:53 PM
2005 Equinox ignition switch removal vadatara2 The Lounge 1 06-24-2009 01:39 PM
Ignition Plug Removal skoot61 2nd Gen S-series (1995-2005) Tech 3 07-06-2008 07:18 AM
ignition key removal bambooboy21085 2nd Gen S-series (1995-2005) Tech 3 11-13-2007 05:13 PM
Tags
02, 89, 95, blazer, chev, forum, ignition, key, lock, removal, remove, replace, replacement, s10, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
