lifted 1984 blazer - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 10-14-2009, 02:48 PM
big84k5 is on a distinguished road
Default lifted 1984 blazer
right now the blazer has a 6 inch suspension lift & 3 inch body lift sitting on 38's i was just wondering if there was any way i could lift in higher without buying a new suspension lift....could i just put 8 inch leaf springs in the rear & 8 inch springs in the front ? if that would work what size shocks would i need ?
Old 08-25-2010, 07:34 PM
sanc7rocker is on a distinguished road
WOW that sounds awesome! I got the same year! Id really like to put a 6 inch suspension lift. Which did you use? whered you get it? thanks
Old 08-25-2010, 08:13 PM
That depends on what parts you have under it now. I hope you aren't still running on the 1/2-ton axles!
Going from 6" to 8" suspension lift, you'll likely have to do a drop pitman arm & a lift steering arm on the axle (if you haven't already gone to cross-over steering). You also may have to clock your transfer case or risk some pretty harsh front driveshaft angles at the transfer case.
Old 08-27-2010, 02:42 AM
Ck1500's Avatar
Ck1500 is on a distinguished road
swartllk brings up some good points! steering will need to be addressed, and he is right about the driveshaft angles they would be / \ looking ... but can be done. brake lines might need to be lengthed also. in my opionin, 6" suspension is about max "budget wise" on a K5... but i have seen 12" lifts on them with 3" body lifts too, and there huge. but to go that high its not as practical. not to mention normally something that high will have huge rubber underneath it. and huge rubber and 1/2 ton axles dont normally go hand and hand. seeing you have 38" already im hoping your running atleast 3/4ton if not 1 ton axles already.
and if you do decide to go for the 8" suspension post some pics on here!! theres not alot of K5 images with the larger lifts here!!!
hope this helps
Ck1500
Old 10-10-2010, 03:39 PM
383snowman is on a distinguished road
i have a 79 k5 that came from fort polk here in louisiana .it has a 8 " lift on it right now.still has the 1/2 ton axles and does fine.as far as steering you will need to get the steering block{goes on axle} and drop pitman arm.as far as your transfer case you can get a 3" drop for it at skyjacker.it is about 35 bucks.
Old 10-10-2010, 06:35 PM
DO NOT get a steering block! DANGEROUS!! If you are looking into that much of a lift, go to a cross-over steering setup.
And the 1/2 ton stuff is fine if you know what you are doing, but so many jump in with big tires and expect to bounce off things like the big boys and that is just not possible with 1/2 ton running gear.
Old 10-10-2010, 07:57 PM
blueblazer1982 is on a distinguished road
8" lifts are stiff too. really stiff . i would rather have a 6" than an 8" , especially if you drive daily. i can't stress how stiff those extra 2" are.
Closed Thread
Thread Thread Starter Forum Replies Last Post
1984 s-10 blazer 4x4 overheating issues cmh_20 1st Gen S-series (1983-1994) Tech 0 11-21-2009 12:39 PM
1984 S-10 Blazer 4x4 5 speed 4x4VegasDan 1st Gen S-series (1983-1994) Tech 3 09-01-2009 04:59 PM
Acquired Free 1984 s10 Blazer 503blazerluv New Member Area 3 03-16-2009 09:04 AM
1984 Blazer S10 w/ 3.4l engine Won't Start! onecrazyfoo4u Engine & Transmission 14 12-17-2008 12:20 PM
1984 Blazer roof normzo Paint, Body, & Interior 1 03-10-2008 12:32 AM
Tags
1984, 19841987chevyblazer, 8, 84, arm, blazer, blazers, drop, forum, k5, lift, lifted, pitman, problems, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
