Motor Stalling Out When Cold???
Old 01-29-2007, 12:13 AM
bluesjam99's Avatar
bluesjam99 is an unknown quantity at this point
Default Motor Stalling Out When Cold???
I have a 1988 Chevy Blazer K5 350 with Fuel Injection and it runs great except, when I start it up cold and it starts just fine, runs a high idle and seems okay. When I take off it to drive it it runs normal but when I drive for a short time at a normal speed of 40 or so, then let off the gas to come to a stop light and coasting the motor just dies. I turn the key and it starts right up again. It does not happen all the time but it does on a semi regular basis. Anybody that can help thank you. If it was a carb engine I would know what was wrong but not so schooled on Fuel Injected motors. Thanks, Doug
Old 01-29-2007, 12:33 AM
SDimeBlazerlady's Avatar
SDimeBlazerlady is an unknown quantity at this point
Default RE: Motor Stalling Out When Cold???
Try putting in a bottle of Fuel injector cleaner
Old 01-29-2007, 12:57 AM
bluesjam99's Avatar
I'll try that! Thanks...Anybody got any other advice???
Thanks,
Doug
Old 01-29-2007, 01:40 AM
Chevy Lover's Avatar
Check for a vacuum leak at the throttle body base gasket. I just spray a little carb or brake cleaner around the base of the throttle body while it's idling to check for vacuum leaks.
Old 01-29-2007, 09:05 AM
drperry's Avatar
Vacuum leaks are evil! They're almost as bad as electrical gremlins! lol
But as Chevy said, check for vacuum leaks, my old Z34 did the same thing, until I got tired of it and changed out all the vacuum lines... Fixed the problem for me... Had I use the carb/brake/wd40 spray method, I probably could've done without replacing all of the lines... But I'm not known for thinking everything through, lol.
If that's not it, there's a slim chance your cat could be acting up... Very slim chance, though...
Old 01-29-2007, 01:54 PM
bluesjam99's Avatar
Thanks, I'll check that too.
Doug
stevenhousden
07-06-2014 05:56 PM
dhmiller80
05-11-2012 07:30 AM
midnightmekanik
02-10-2011 12:39 PM
ravenhurst
15
04-26-2009 07:53 AM
as2higpark
10-18-2007 12:18 PM
Quick Reply: Motor Stalling Out When Cold???
