Need help heat wont work for nothing - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 12-13-2011, 09:03 AM
88k5high is on a distinguished road
Default Need help heat wont work for nothing
My 88k5 heat is like not working at all i did all the basic checks for anti freeze and stuff like that but it just blows cool air out even if the trucks been running for a few mins it still doesnt warm up anyone know anything else i could do to fix?
Old 12-18-2011, 10:05 AM
Z71_Guy is on a distinguished road
does the truck to operating temp. if not replace the thermostat. if it does then flush your heater core
Old 12-19-2011, 07:15 PM
abig84's Avatar
yeah if thermostat is stuck open it prevents the antifreeze from staying in the engine long enough to warm up.
Old 12-26-2011, 07:38 PM
rockhard69's Avatar
rockhard69 is on a distinguished road
I just went through that problem on my 88. The thermostat could be bad, use the 195 degree one.
You can also check the heater door just inside the firewall behind the blower. You can remove the glove box and check and see if the cable for the heat is moving the lever for the door.
The other thing to check is to see if the door is slipping on the bar itself. If it is it will not open enough to allow the air to flow. It happened to mine and we had to spot weld the door to the shaft, heater is working alot better now.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Help, nothing engaging on 4 wheel system except for the front differential. lidster 2nd Gen S-series (1995-2005) Tech 1 12-12-2013 10:46 PM
NEED HELP! Blazer wont shift into park starter wont crank 97 2dr 4wd dj00140 2nd Gen S-series (1995-2005) Tech 1 05-20-2013 07:37 PM
Gauge cluster wont work and battery wont charge. slammed95blazer 2nd Gen S-series (1995-2005) Tech 1 10-27-2010 08:24 AM
89 s10 blazer 4x4 wont work?? need help 89blazer89 Steering, Suspension & Drivetrain 2 02-20-2009 01:57 PM
slow starting, heat wont work chimpy581 2nd Gen S-series (1995-2005) Tech 10 09-12-2008 02:58 PM
Tags
05, 1985, 1988, blazer, blow, chevy, doesnt, dont, heat, heater, hot, k5, make, warm, wont, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
